Easyeieio
Hi guys, sorry if this has been covered previously, have searched but not found anything directly relating to my query, or the way I want to do it.
I'm converting my T6 to a camper, and want to keep the existing load lights, but run them from the leisure battery instead of the starter battery. (NB: 1 Leisure battery is grounded to vehicle . 2 I don't want to run cable from leisure battery to vehicle fuse box)
I'm intending on doing this as follows, rewiring direct to the light fitting
Remove existing Red and black wire +12v Live feed from light fitting completely, and terminate (will be unused forever)
Connect a new fused +ve to the light fitting from the leisure battery
Remove existing Solid brown , permanent negative from light
Connect new permanent negative from leisure battery to light.
LEAVE existing switched -ve connected to light fitting.
I'm hoping by doing this the light functions ( door open on / permanent on ) will still function as before, only change being power coming from leisure battery.
Also that the timed off will no longer happen, as +ve feed now taken from leisure battery.
Can anyone confirm that this will work without problems?
Last question; is it even worth it - would I be better off just changing the bulbs to LEDs and running from starter battery and leaving wiring as is - presume LEDs would take forever to flatten the battery as draw would be so minimal
Ian
Ian
