Thank you, I'll have a look at this one
Thank you tooOr the drift eco which is a little bit cheaper
Drift ECO 12V 100Ah Lithium Leisure Battery + Bluetooth
Now with Bluetooth connectivity - the Drift ECO 12V 100Ah lithium battery boasts a fantastic 1,250Wh capacity, making it ideal for powering even the most demanding applications.www.fogstar.co.uk
Thank you aswellEco-worthy do one around £200 with Bluetooth and low temp protection, fits on its side
Depends...Just running the lights and the dometic fridge is the 100ah ok or any suggestions?
That's really helpful thank you!Depends...
On how long you want to spend 'off grid' with no charging.
A normal 50l fridge will use 1-1.5Ah per hour, so around 30Ah in a day. So realistically you might get 2-3 days from a 100Ah battery with no additional charging.
Does this one have to go on its side or does it fit upright?
Thank you, I think we are going for this oneI run it upright under my drivers seat. It's tight but doable.
Thank youLiFePO4 batteries can be mounted in any orientation.
I can't fault it.Thank you, I think we are going for this one![]()
Great! We've done abit of research seems good and just what we needI can't fault it.
I had to put it on its side as I have a swivel. Not tried upright without the swivel but looks like others have made it work. It’s been a great battery.Does this one have to go on its side or does it fit upright?
Thank you, we don't have a swivel on the drivers seat so hopefully it'll fur upright but either way sounds like it'll be fine. Ordered it last night...on pre orderI had to put it on its side as I have a swivel. Not tried upright without the swivel but looks like others have made it work. It’s been a great battery.
