JanThorben
Hi everyone
We have a VW T6 Transporter, 2016 (75 kW TDI, CXGB engine), and want to convert it for light camping use – nothing fancy, mainly:
The van came with a factory dual battery setup (starter in the engine bay, AGM 75Ah Varta under the driver's seat, split-charge relay, factory cable 7H0 915 531 routed underneath the vehicle). The rear AGM is probably end-of-life after ~10 years – on our last cold-weather trip the factory water heater ran a few times overnight, and in the morning the van wouldn't start.
Trying to figure out the best path forward:
Questions:
I'm reasonably handy and would do the consumer side myself, but anything touching the factory system I'd rather take to a shop.
Thanks for any tips or experiences!
- some LED lighting in the back
- charging for laptop and phones
- possibly a diesel air heater later
- Just replace the AGM 1:1 (~200 €) – factory system untouched
- Replace AGM + add proper consumer side (fuse panel, USB-C PD, LEDs) – camping loads on the seat battery
- Replace AGM under seat directly with LiFePO4 100Ah + DC-DC charger instead of split-charge relay – would need to adapt the factory energy management
- Add Lithium 100Ah as third battery in the back with DC-DC charger (Votronic 1212-30 or Victron Orion XS) – factory system left completely alone
Questions:
- Has anyone replaced the factory AGM under the seat with Lithium on a T6? How did you deal with the battery sensor / pyrofuse and coding?
- If Lithium goes directly under the seat: does the VW energy management get confused, or can it be coded properly?
- Or better to add a third battery in the back, factory system untouched? How did you route the charge cable?
- Which battery does the factory water heater typically draw from on a T6 – starter or second battery?
- For an AGM 1:1 swap: does it need to be coded, or is it fine without?
- Split-charge relay after 10 years – how do you check if it's stuck closed?
