Lining walls, and back door
Mbr_tattoist
hello guys, so currently insulating the t6 a question I need to ask before lining is
Do you put all the panels popped back in place and line over the entire lot or
Line the majority and do the back panels and door panels separately lined then pushed in place to allow access to ...lights , side door ..... back door bits and bobs
I love the look of smooth lined walls etc but I don’t know if need access points
I’m fully kitting out as a full camper, kitchen rock and roll bed
It’s a LWB
Generally and personnaly I believe that the jobs looks better if you remove and line the panels individually then reattach using hidden clips (check out MVM hidden clips).
This way you can always get access behind panels should you need to..
Depending on your material size will depend on where you start and where you try to hide joints and seems.
@Absolut5 @Dean@VanDoc @slidepods have some great examples in their media pages. The more metal work you can do in one hit the better...
Absolut5 's thread was my bible when I carpet lined mine.
I managed to get round all the metalwork in one go without any joins.
T6 carpet lining
As above if you are going to use hidden clips use the MVM ones as they are better quality than the ebay ones
