Hey all
I am new to this forum but I could do with some help if that's ok. I have just installed the lower grille DRLS to my T6 2015-19. I got the DRL kit from Justkampers (no instructions provided) and the wires from the canbus are red with in line fuse which I believe should be connected to wire 1 in the headlight harness (power to DRLS with ignition), black to ground and a yellow wire which I believe should be connected to the headlight wiring loom/harness wire 10 (allows for dimming). The main problem is that the DRLS will not dim with the sidelights turned on. I have the Transporter HQ V2 headlights but I don't think they should cause any problem. Has anyone else fitted the justkmapers kit and if so please could you let me know where I have gone wrong.
Many thanks
Bash
Many thanks
Bash
