Like so many other folk, my factory kombi rear windows leak when it rains. Refusing to accept that the only way to resolve was to take it back to the stealer, I set about stripping the window out to figure out what was wrong.
This will have several posts in order to get it all in due to the number of pictures.
Stage 1 - Removal
The top and bottom trims over the handle mechanism need to be removed.
The top one needs to be prised from the top, and the bottom one; from the bottom. This is because there is a little tab in these locations.
This cover will then slide away from the window handle where it has a channel that secures to the handle locking pin (hence why it needs to be popped off from the other side).
Repeat this procedure for the other trim.
Next you will need to remove the handle. Whilst holding the handle flat, using one hand, with the other pull the thin securing pin out, keeping the handle in the flat position pull it away from the window.
TIP: put the pin straight back in as the handle is spring loaded, putting the pin back in keeps everything where it should be!
This will leave you with the locking mechanism exposed.
There are two plastic pieces that retain the springs.
These just pop out using a trim tool. Remember which one came from where as they only go in one way.
With both of these out you can slide the centre piece off its peg which will enable you to manipulate the pins out of their channels.
At this point you can slide the window open. On the leading edge you will see a little metal guide at the top and the bottom.
Pop the bottom one out of the track by using very light upwards pressure on the window, using a trim tool to prise it out, whilst pulling the bottom edge of the window towards you.
The top guide will now pop out simple by applying some downwards pressure to the window.
With these guides out, rotate the window 90 degrees so it is against the back seats. (Orange arrow).
Now pull the bottom of the window towards you and push the top away (purple arrow). The window is now out.
Obviously this all needs to be done from inside the van with the side door closed. Probably should have mentioned that to start with!
Stage 1 - Removal
