I have done exactly this. I have used 7mm2 wire (60amp) which fits nicely inside 7mm diameter split convoluted conduit. If you follow the brake pipes down the nearside of the bulkhead, they are held by plastic clips which have an empty clip on each, the 7mm conduit is a perfect fit into the spare clip and looks tidy and OE. This gets you to a position underneath the passenger seat, from there, the conduit can be secured with cable ties accross to the offside, going above the exhaust heatshield and along the offside to the rear, there are lots of ready made holes to use for the cable ties. You might be able to use an existing grommet to come up through the floor in the rear corner, I drilled a hole to bring mine up in front of the wheelarch to where my batteries and B2B charger are mounted under the bed.
