Language setting in vcds.
Skyliner33
VCDS User
T6 Legend
I've just been out looking at my vcds to see if I can get a few things to work.
However when I go into Adaptations, then in the drop down menu, everything is in German. Im sure it didnt used to be and a check on you tube shows other peoples are not. Is there a setting I've missed?
Also whilst I think about it when I try to select 46-Central Conv. I get an error message saying (iirc) cant communicate with the....
Which module? There certainly are still parts in VCDS which are not fully translated.
Are the adaptation named differently if you extract all available adaptations into file, e.g as here --> https://www.t6forum.com/threads/discover-media-radio-navigation-retrofit.27968/post-386528
No, there's no setting for language.
There shouldn't be module 46 on any T6.1. All modules onboard are listed under VCDS tab "Installed".
Cent. electrics
Adaptations
I’m trying to find the setting for the comfort turn signals to change 3 to 5
my mistake, I was as looking at this screen
I’m getting the adaptation files now and will pm you.
Reactions: mmi
Bugger just had a go at this and need security access?
Just had a go at this and need the security access code. Can you point me in the right direction to find it please?
Try 31347 - VCDS should tell the code when you hover mouse over the field.
More codes just in case ;)
Thanks, knew I had forgotten something. Thats the code I used for the mirrors lol.
Reactions: mmi
I’m just looking the mouse hover does not work :(
