Sold Kombi Bed System - Carbon Fibre Finish Ply
T6dder
Web/graphic designer
I am having my Kombi converted so I am selling my Kombi Bed System made from lightweight ply with a carbon fibre effect finish and grey trim.
The system can be seen here: Kombi click together bed
This cost me £400 new. Im looking for around £195 ono.
Collection from Weston-super-Mare. I could post but wouldn't be cheap.
Hi, I know website shows sizes - but just want to be clear ....... Can you confirm the H, W, L pls? Also does it come with the foam mattress as per the website?
I have a T6 Shuttle T32 LWB and this could be ideal. Let us know asap pls. Cheers Paul
Hi @Bluey,
From measuring the separate sections here in my office the dimensions are as follows: H-59cm, W-150cm, L-192
Which part are you concerned won't fit and I can double check any measurement? I would have thought the inside wouldn't differ from a SWB Kombi, except that you have more rear space.
No mattress included with this.
Hi @Bluey,
Hi it is the 2 vertical stands that run form the back of the van towards the front ( i.e these support the actual bed table) that may not work with my plan ..... Can you give me the measurements of the 2 Vertical stands please? Also when they are locked in to the "Bed Table" - what is the distance between the 2 Vertical Stands?
Hope this makes sense, thanks for the quick response, Paul
The Gap between the vertical uprights is roughly 117cm
The Length of the upright supports is 116cm & height is 59cm
The clearance height under the bed is roughly 42cm. (see pic)
Thank you so much for your answers. Unfortunately this is too long for my Van-damn! Many thanks again and good luck with sale. Cheers. Paul
Hi there, is this still available?
Does it have the mattress mentioned on the website? and I don't suppose you have any more pics?
Only in Bristol so could collect
It appears on the website that you can buy the bed for £180 (pick up only). This would be wood finish rather than the carbon effect. I am ordering one for a Transporter that has an extra prop due to the absence of 2nd row of seats.
