Is this what the t6 audio connection looks like?
sipep
Hi
I have purchased a used android headunit.
He says it fits the harness that looks like the attached.
Is this this connection the same as a 2019 t6?
It's really easy to pull your head unit and take a look at the plug that the harness will connect to. Carefully lever off the vent surround panel, remove the four torx screws, and the carefully pull the unit out.
There's enough slack in the loom to hang the unit out of the hole - I use a towel to protect the dash from getting scratched by the head unit housing. Takes one minute.
The loom connector has a cam lever that you move to pull them apart.
This thread has some useful pics to help: [GUIDE] Head unit removal and rear speaker wiring
Hi, he's not posted that headunit yet.
But this is the connection he's emailed me
The pins are all in the same place, however sometimes aftermarket radios require an adaptor harness to swap the power wires over and retain the factory parking sensor display and steering wheel controls.
