Is there a harness to add a piggyback amp?
GavMc P11GT
I have a small Vibe amp I want to it to the van is there a quad lock I can buy that has iso male and female in the audio half of the harness that I can use
So have re pinned the audio side that’s gone to plan however the power side looks more tricky than thought I have nowhere for or I’m not sure on where to connect Red live yellow live and the remote live
Any help on this would be greatly appreciated I’ve added a line out converter and a vibe power box65.4 to composition media
Also the black dab fakra is different the one on the composition is bigger than the standard 6 button t6 wireless anyone know of an adapter?
Ah that’s what I had in mind to be honest. I’ve part invested myself into re pinning the existing harness. Which to be honest the audio side worked fine and is all back in the stock plug. I have the pin release keys so is easy. It’s just the power side I need to work on.
The remote live can apparently get the same signal from the ground wire according to the instructions. Which would leave remote live and ignition live.
There’s a power and ground in the quad lock so will have to test if that’s permanent or ignition live then that will just leave one live left to find and I’m all sorted.
I’d rather pull the required live from the stock harness if possible but can obviously pull from the firebox as a last resort.
Or failing that re-pin back to standard and spend on the replacement harness.
