Every now and then since I bought my van about 2 years ago I have had an issue where it fails to start, the engine turns over as normal but doesn't fire even if left turning over for several seconds.
When this happens, it usually happens repeatedly but if left for a few minutes will then start up. I have noticed that it seems to happen more often during cold weather and occurrences are clustered so, it will go weeks or months without happening and then happen on almost every start for a couple of days. Recently the occurrences seem to have become more frequent and mean I just can't trust the van.
I don't believe any fault codes are consistently logged relating to the issue since I happened to clear the codes one day, then immediately experience the issue and then rescanned with nothing logged.
I bought OBDeleven but found I couldn't get it to read most of the logging values mentioned in another thread so finally decided to stump up for a VCDS cable as I knew a garage would get nowhere without being able to replicate the problem.
Typically it was then faultless for a week or so until tonight leaving work when it happened so consistently that the battery got worn down to the point that the engine cranking revs were dropping quite severely and I figured I'd call the AA. An hour later and still no sign so I thought I'd give it one more go, even with a weak crank it then started up on the second go and I drove home with no problems.
Fortunately, I'd expected this and had the VCDS cable and a laptop in the van so managed to capture a few logs as recommended in another thread, I'm hoping someone with more knowledge than me might be able to advise where to start trying to diagnose the problem.
The fuel pressure never builds up but I've no idea where else to look.
TLDR version:
Van doesn't start, logs captured, fuel pressure problem(?), please help!
Apologies for the multiple logs, I tried it several times as I wasn't sure if I was capturing enough info in enough detail so tried multiple times. I've also attached a block map from last week when the van was starting.
Thanks in advance!!!
TLDR version:
