Importing T6 California
Joey
Hi.
I am importing my LH drive drive 2019 VW California from Switzerland to the U.K. and I need to move the fog light to the offside.
I figure I need a new light cluster and I need to switch the wires across. Has anyone done this? Does any have a wiring diagram so I can figure out if there is just a pin I can swap over.
I would like to avoid dismantling the rear door or splicing wires.
Many thanks
Joey
Have you checked what the van actually has?
My LHD (just a plain T6) has fog lights both on left and right?
Hi.
Yes I’m afraid it doesn’t but it was just a quick check. I’ll have a look to see if it’s there and just not plugged in.
Reactions: mmi
Hi.
The easiest thing to do, is to run a single wire from existing rear fog light to the other side. Splicing is unavoidable and I don't think you need to buy new light cluster.
Thanks.
I’ll look at what is actually there tomorrow.
I’m afraid I have fog light near side and reverse light offside and they need to be the other way around. Both are in the same place at the bottom of the cluster.
So I have found where I can swap the wiring over. Under the drivers seat.
What extraction tool should I use on this plug? Swapping wire 3 green and black and wire 4 gray and white should swap reverse and fog over.
