I'm wiring the new lights in the back of the van and now realise this isn't my area of expertise. Along with most things that need to be done on the van
I will be running four 2w LED dimmable puck lights from Marvix on a single circuit. They will be connected to an Acegoo dimmer switch which manages all the dimming and memory itself. (see picture)
When it comes to cable size, I'm concerned I'm misunderstanding things. If the four 2w LEDs total 8 watts at 12 volts (confirmed by testing the draw on my river 2 max), does that mean in total they will draw 0.67 amps? Does that mean the whole circuit can use fuses and wire rated for 1amp? That seems low and based on other wiring diagrams I've seen, I was looking at using a 5amp fuse and 1.5mm2 cable.
That leads me to the second question. I'm looking at 1.5mm2 cable on 12voltplanet and it says it is rated at 16.5amps. A quick search suggests 1.5mm2 is rated somewhere between 10amps and 14amps. Is this reasonable or should I be factoring in significant safety margins?
I'm looking to charge the river 2 max from a 12v socket while driving and it says it will draw 8amps/100watts max from the car input. I've seen this pull 90-100watts from a spare car battery but the 1.5mm2 cable and 14AWG connectors I was using to connect a 12v socket got very hot but should be ok up to 15amps.
Can anyone help educate me on this?
Thanks!
Thanks!
