Being a van forum hopefully some plumbers amoung our community or some avid DIYers!
Recently discovered a crack in the acrylic bath in the family bathroom. Its not leaking but has increased its priority on the job list.
My main question is.... Are there any brands of toilets/sinks/baths that you prefer to fit as they install nicely, seal well when assembled and cause minimal revisits.
An example - we live on an early 2000’s estate and the builders used Ideal Standard. Couple of weeks ago fitted a new toilet fill valve for our neighbour. Because of the shape of the floor of the cistern, the fill valve touched the side of the tank before the seal was water tight so ended up using silicon to seal it (like the builders had done). It may have been a one that slipped through quality control as ours have all been fine. This is the type of thing I mean.
Any brands / suppliers recommended, any to avoid?
We’re still at the design stage as there is currently a lot of deep boxing in on the window sill which is wasted space. Possibly having concealed cistern. Also putting a pumped shower over the bath so need a water tight shower screen (never been a big fan of them!)
Any help or suggestions greatly appreciated.
Regards
Ian
Regards
Ian
