Help to find loom plugs or part numbers please.
Skyliner33
#rallyeroamer
VCDS User
T6 Master
I am trying, unsuccessfully to find the 'sockets' that these plugs would fit into, to make up some connectors to the OEM loom.
I have 2 part numbers for the bits I have got, but cant find the parts I need.
130 972 704
600 972 704
These are the part numbers on these (I think either will do):
I found the 2 pin connector below on ebay that looks similar but wrong number of pins. Are yours interior light
If you are looking for an in line connector, what about looking for a different style of VW plug that uses the same connector type. Then simply swap over the connectors.
Part numbers can be totally different for 2 halves I have found in the past. Also some connectors do not have a corresponding 1/2 as they plug into a piece of hardware with an moulded in connector.
Searching ebay for where they are used can sometimes throw some results up.
Thanks, the parts I showed in the photo plug into the OEM door speakers. I want to fit aftermarket, so need to make an extension loom.
