Help needed with heated seat pads please.
spikesykes
Help needed please.
I have purchased the Dometic mah 300 heated pads. The t6 seats have stripped down ok, the metal wires are a pain in the, but I managed to get them off.
When refitting , the rods sit in a recessed pocket but the heat pad will have to sit under the rods, this could cause a short circuit if it rubs through.
Normally you would cut a section out and insulate but the wire rods are wider than the heat pads and you cannot cut the copper wire at the sides. Any help and advice would be much appreciated so I can get this job out of the way. I have a few pics.
Personally I’d put the heat pad over the rods and protect the ends of the rods or if not possible wrap the rod either in heat shrink or tape to prevent wear on the pad and the inevitable short
