Help Error message
JimVee
Retired
hi guys just attempting my first vcds. Ticked the boxes for auto lock and unlock but when i press DO IT
The pic below comes up, any help would be appreciated done it three times now!
Check the equipment number in the box on the bottom right, its currently 559828 and change it to something below 262143 and you should be good to go, i normally use 123456
@Pauly. Thanks, you are now officially my hero. worked a treat and just done the km to mph too..:)
Worth the expenditure then mate.. Multiple upgrades for one price, without getting your hands oily! :rofl:
Have you looked at the VCDS coding list - https://www.t6forum.com/downloads/categories/vw-t6-vcds-information-guides.9/
As a VIP member you have access to download this, is gives you a list of most of the available changes possible without trawling through all the screens on your laptop and shows which module/what byte so you can go straight to it
It only lists the coding options and not the adaptions lists but this covers most stuff
Yes mate, downloaded that and used the figures to confirm what module I was looking at, thanks.
