CRS is in Cannock, I'm in Aldridge which is absolutely nowhere near Walsall obviously!!Anywhere near the west Midlands?
No way!!!!! Ha ha.CRS is in Cannock, I'm in Aldridge which is absolutely nowhere near Walsall obviously!!
I take mine to Midland VW in Norton Canes for servicing and whatever needs doing, always been good and relatively inexpensive! I was burnt once by VW Birmingham and wont go back.No way!!!!! Ha ha.
I think I know the place you mentioned. As I searched around Aldridge too. I use Car Friend for servicing. As I'm also in Aldridge!!
Small world.
Car Friend seems to be ok. They've sorted the issues out which I've had.I take mine to Midland VW in Norton Canes for servicing and whatever needs doing, always been good and relatively inexpensive! I was burnt once by VW Birmingham and wont go back.
Have you got a picture of your van, I'll keep a look out. Promise I won't flash my lights. Do you ever get that? Other VW vans letting on. It's not a sad thing, I'm just a bit shy ha ha.Mojave Beige?
Steve? I say Steve?! Are you out there @CRS Performance ? He's probably under a van, he will be in touch I'm sure!Car Friend seems to be ok. They've sorted the issues out which I've had.
They couldn't remove the plugs, the siezed glow plugs. Told them if they didn't have to tools, or the skill set, to not try. Otherwise, obviously head off.
I could off drilled and tapped them myself ( I've done this many times, but on aircraft ). So I thought I'd search for someone who does this on cars/vans. James Price in Walsall. Pricey but got the job done. Shown me the two plugs he had to drill and remove.
So.....have you had your suspension set up done off CRS?
I'm not looking at lowering. Maybe a lift, not massively. Also....I've seen vans with a lot higher lift on the back, and lower on the front. Though this van has like low profile tires etc. That's not my vibe. Well....not so noticable.
I'm definitely going to get in touch with CRS, they came up in the search when I initially started researching.
Ah, the posh houses!Nice Van that pal. You're probably about the same distance from me....The Glades.![]()
Ha ha......don't judge pal. It's all just a facade. I drink vodka and coke on the toiletAh, the posh houses!
