Haven't seen any 60mm reducersSplit the outlet and use 2 smaller vents to fit in there? Or find a rectangular one ( haven't seen any for a while though ).
Perfect thanks for your explanation, also the fresh air in is in door step due to sucking in warm non exhaust air can we not fit this anywhere out of eye sight ?I only have a 55mm to 45mm reducer and a 55mm Y-in my spares box.
60mm to 40mm reducer - Duct Hose Reducer 60-40mm BUT the heat rating needs checking first - it needs to be rated at at least 135 degrees. If suitable you would need 1 x 60/60/60mm Y-splitter or Tee, 2 x 60 - 40mm reducers and 2 x 40mm vents as you cannot just step down to just one 40mm outlet.
That would all take up more valuable space so I would be inclined to use a rectangular vent that sits further in instead of the lash-up using a 60mm round one like above.![]()
Sorry underneathIs the heater mounted under the van or under the seat? I assumed that it was under the seat with the outlet vent being placed there.
again thanks what about fresh air inYou can run the duct further back underneath and come out at the base of anything along the side. It doesn't have to be the driver's seat base.
Mine are here ( red arrows point to area where they are in the seat base ) from a heater mounted underneath ( they can go further back than that even ):
Something like this?
What?! I never knew this was a thing! How do I go about doing this please? I looked through the manual but couldn't see anything suggesting I could adjust the temp. And yeh I have the stc200As above, but not at that price! Try 60mm Air Vent Outlet Auto Heater Duct Warm For Eberspacher Webasto Propex | eBay
But ....... the question is why are you only running it at full 2Kw heat? It will adjust down to 0.9Kw if you are referring to a diesel Webasto 2000.
Typical of the catch of Amazon - always look for a better price elsewhere!!As above, but not at that price! Try 60mm Air Vent Outlet Auto Heater Duct Warm For Eberspacher Webasto Propex | eBay
There is an almost flush version that will direct the airflow at 45 degrees and obviously not stick our so far. And no I didn't say that was the cheapest place to buy, it's just an example.This is what I have but even with that it comes out more at 45 degrees than 90 so still catches the edge of the unit unfortunately.
