Headlight Level Adjustment?
Rabbit
Hi
I have recently changed the passenger side headlight unit as I broke the plastic front on the 1st one, but I noticed tonight that the beam is now lower than the right side.
Do I have to take the bumper of again and loosen the holding bolts on the underside or is there some screw I can adjust on the headlight to bring the beam back up to where it should be?
Whilst I’m at it is there also a way to adjust the left right angle? Think I’m ok but might as well ask just in case
Have a look on top off the headlights and you will see big white plastic bolts/screws these will adjust the light angles
I think they have large hex heads on them with slots in the middle for a cross head screwdriver
