Headlight Flickering
Mavis628
All the messing about with the bulb error light and now I have a dipped beam flickering, noticed it when I pulled up to the garage door, looking at the headlines front on, I can see the dipped beam light beam is different.
Loose connector or dodgy bulb?
I’m not sure as useless with tech stuff, will check it out somehow, wondered if anyone else had this problem, if I code the lights somehow can I get rid of the loom the headlights came with tonstop canvas error coming up?
What light units you got/had/retro fitted?
H4, H7, OEM LED, H4 with 3rd party LED bulbs?
Did you ever get this sorted?
Pretty annoyed that spent a load of dollar on these. Then their solution to the error light is ‘go and buy vcds’ then switch the lights on and they are flickering, but mine do it more when coming off the pedal at approx 2k rpm. I can repeat it time after time. Fine if accelerating, fine if holding power around those revs. Wondering if voltage/current related.
Mine still flicker slightly travelling life are not helpful after you have bought there stuff imo
I had the same issue. with the travelin-lite bulbs.
After two months one of the lights popped with only one of the LED's working.
Changed them out for another make and had no issues since.
What other make of bulb did you use? These are the expensive gen2 Phillips that are flickering.
