Has this VAG scanner cleared AdBlue system events?
transportør
Hello! I've been using this particular scanner to monitor how often my 2018 T6 shows SCR-related fault codes by clearing them intermittently. Error code reader for VAG
In your educated opinion – has the scanner also erased all records from the vehicle's memory regarding the AdBlue warning light being briefly on and off a few times over the last couple of thousand kilometres?
I'm asking this in advance of taking the vehicle to an official VW service centre for diagnostics and to assess the need for repairs. Thank you!
Not according to its own technical description - see 2nd paragraph.
Something like an iCarsoft V3.0 probably can.
In the 2nd paragraph it also says ”does not apply to VAG vehicles”. In the latter part of the description it says that the scanner doesn’t reset the check engine light following the same exclusion of VAG vehicles, and because I know for a fact that this scanner can reset my T6’s check engine light, the description is a bit confusing. I thought maybe people here could answer my question based on the protocols listed or such.
In this case it would be a good thing if there still would be log of AdBlue light events.
