Hammock Suspension Eye Bolts
I have recntly purchased a T6 Kombi which has been fully carpet lined by the main dealer. I want to put front and rear Eye bolts to suspend a hmmock from. I can feel that there are oval access holes for the tailgate hinges, which will give me ideal access to fit the rear ones but if I cut the carpet lining around these then I would like to fit a blanking plug over the holes I assume these were originally fitted prior to carpet lining being done.
Anyone have any ideas of a part number for these please?
Also i would like to fit eye bolts just behind the top of B pillars on each side. If I drop the head lining, is there room between the roof and the framing beneath it to slide a 6mm eye bolt backing plate in to the bit that sticks out from the sliding door frame at top front of doors frames.
Any pics would be helpful as I've not seen mine before it was carpetted
Hey Pedro!
Awesome idea re hanging a hammock. Did you ever achieve this? Where did you add the eye bolts?
Before a had my van converted I considered making a raised bed / hammock by using ratchet straps / canvas sheet between B & D pillars.
I’m not sure that a single skin panel or pillar hole will take much loading without some reinforcing.
did you get this set up in the end ?
