R Rg_ Member T6 Guru 5 Feb 2020 #1 Hi guys just wondering what type of grease to use to re-grease the sliding door and door hinges. Thanks
Dilbert Not All Who Wander Are Lost T6 Guru 5 Feb 2020 #3 Rg_ said: Hi guys just wondering what type of grease to use to re-grease the sliding door and door hinges. Click to expand... Which part of the mechanism do you mean? The roller track needs to be a dry lubricant otherwise dirt, sand and road grime will stick to it.
RedUn Kombi... work in progress VIP Member T6 Legend 5 Feb 2020 #4 I use spray lithium grease on mine, smooth as you like and allows you to get up on the roller and channels without taking anything to pieces
R Rg_ Member T6 Guru 20 Jan 2021 #5 Dilbert said: Which part of the mechanism do you mean? The roller track needs to be a dry lubricant otherwise dirt, sand and road grime will stick to it. Click to expand... Just all of it, the roller on the slide door and the front door hinges.
kurienp Senior Member VIP Member T6 Pro 21 Jan 2021 #6 This one. spray and if in excess, you can wipe some away with a dry cloth.
R Rg_ Member T6 Guru 21 Jan 2021 #7 Kurien Philip said: This one. spray and if in excess, you can wipe some away with a dry cloth. View attachment 99553 Click to expand... Thanks mate. Will pick some up.
