Glowplug relay
J_Con19
VCDS User
Anyone able to give me a part number for the glowplug relay on a 2016 T6 and where to find it?
I'm having issues with my caddy so hoping to compare and hopefully rule out this if it's possibly the same part number.
The glow plug control unit J179 is located in the E-box under the battery
The automatic glow period control unit - J179- is installed in the electronics box in the engine compartment.
♦ The assigned position in the relay carrier depends on the equipment ⇒ Current flow diagrams, Electrical fault finding and Fitting locations.
– Remove battery tray ⇒ Electrical system; Rep. gr. 27 ; Battery; Removing and installing battery tray .
– Remove electronics box cover ⇒ Electrical system; Rep. gr. 97 ; Relay carrier, fuse carrier, electronics boxes; Removing and installing electronics box .
– Pull off automatic glow period control unit - J179- from slot in electronics box in engine compartment ⇒ Current flow dia‐ grams, Electrical fault finding and Fitting locations
Thanks loz roughly where I thought, fingers crossed it's the same part number!
