Pretty sure that the actual glow plugs don’t produce a fault code or illuminate a fault light. The control and wiring may produce a fault code?
@mmi will know for sure.
Definitely glow plug fault with engine symbol showing
1 Fault Found:
15918 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 00 [11101100] - Electrical Fault
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 129172 km
Date: 2078.14.26
Time: 17:22:30
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 12 C
Intake air temperature: -1 C
Ambient air pressure: 990 mbar
Voltage terminal 30: 11.851 V
Unlearning counter according OBD: 40
Pre-glow time: 2.5 s
Glow status: Readiness heat
Outside temperature sensor 1: B1: raw value: 11.5 C
Regens also been completing ok. I do mostly shortish journeys and it seems to do them about every 200 miles. My son's car broke down and I've been taking him to work this week and I've been getting a bit concerned that a regen hasn't taken place yet and it's just over 290 mile since last regen. Just taken these readings this evening:
Address 01: Engine (04L 906 056 MH)
20:28:38
IDE00430 Particle filter: field regeneration request status no request
IDE00431 Particle filter: field regeneration lock status 8
IDE00432 Particle filter: time since last regeneration 704 min
IDE00434 Particle filter: soot mass calculated 28.23 g
IDE00435 Particle filter: soot mass measured 15.66 g
IDE00436 Particle filter: kilometers since last regeneration 503.8
From what I've read seems like DPF should start regen between 18-25g soot mass so hopefully it's just that it's producing less soot because I'm doing longer dual carriageway journeys.
