I’m currently stripping and sound deadening then insulating my van. Initially I didn’t think the van had anything installed but when I removed the carpet lining and panels, I found what looks like some thermo liner. It might be a cheaper imitation but the issue is that none of it has really remained stuck to the panels. Has anyone else had this issue?
I bought some thermo liner extreme and I’ll be fitting it on dodo mat pro rather than direct to the van metalwork, but the liner isn’t as sticky as I expected. I’m worried the same thing will happen to the new stuff I fit.
Has anyone used or needed to use adhesive between the sound deadening material and the insulation material? I’ll also be installing fleece after the thermo liner so things will be more packed in this time.
Here is a picture of the current insulation I am removing. The foam is firmer than the Thermo liner extreme I’m replacing it with. Maybe it was a cheaper version?
