Kedlestone
Hi all,
I’m looking for some clarity on the gas drop vent placements. As I understand it the first one is in the base of the gas locker (if using one). The second one is in the van floor.
From what I’ve read some people say you need a vent at the point of where there’s a join in the gas pipe work i.e under the cooker. If this is the case mine would fall under the fridge. I’ve also read you should keep the vent clear of obstructions, for obvious reasons.
My fridge is raised off the floor slightly via its legs, so would that be ok to put the vent under it or shall I move it to the next cupboard floor area over?
Thanks.
Thanks.
