Fuse location help please
piper1
VCDS User
Hi can anyone help me to identify where this fuse should be located please.
It’s a piggy back fuse with a 10- and 2-amp fuse.
I’m pretty sure that it’s my reversing camera the type that allows you to view the image on a rear-view mirror, that’s the only thing that doesn’t appear to be working at the moment.
I, thinking maybe the 5th-fuse holder down on the left-hand column?
Thanks Kev
Look for an empty slot that has a metal terminal in both sides. It goes in there. And while your on, the piggy back that has the fuse pointing down is in upside down. The circuit it’s supplying is not fused correctly.
Thank you very much for the reply, the other two piggy back fuses are what i think is the wiring for a 13 pin socket to a new tow bar i have just had fitted last week, and i wasn't impressed with them at all.
