Full Feelart Onesub set up including plug and play loom for OEM head unit.
Front Speakers
25MM Silk ball top diaphragm treble/ N40 advanced neodymium steel magnetic circuit.
Steel-and-iron mid-bass stand/ special pulp board mid-bass sound basin/ 10OZ magnet.
Two-layer aluminum sound coil/ Symmetrical passive crossover.
Type 2 way split speaker
Size 165MM(6.5")
The Number Of Loops 2 way
Sensitivity 91dB
Impedance 4Ohms
Maximum Power 120W
Rated Power 60W
Frequency Response 60Hz-20000Hz
One Sub (subwoofer)
4.1 Channel DSP power amplifier and subwoofer audio system
Directly connected to the original car, audio upgrade without any loss; digital blue-tooth lossless transmission, capable of getting songs from mobile phones.
Highly-efficient bass, compensating the low frequency flaw of the original car; efficient power amplifier, making full use of the horns in the car.
DSP custom-made EQ, only for you; DSP customized delay, presenting you the excellent sound performance.
Performance Parameter
Main Chip Resolution 48 bits
Audio Sample Rate 96KHz
SNR(signal to noise ratio) ≥110dB
THD (total harmonic distortion) ≤0.02%
Frequency Response 10Hz-22KHz
Rated Power 30W×4(full frequency)+60W×1(low frequency)
Maximum Power 60W×4(full frequency)+120W×1(low frequency)
Mains Input DC9V-15V
Size(L×W×H) 345mm×245mm×70mm
Manchester based if you want to collect or can post no issue.
£450 ono
Front Speakers
Size 165MM(6.5")
Sensitivity 91dB
Impedance 4Ohms
Maximum Power 120W
Rated Power 60W
One Sub (subwoofer)
£450 ono
