Fuel pipe split
Jfoz
Hi all,
my fuel line split in the engine bay near the battery, it was temporarily fixed the other day, cut out the split and tied/clipped a piece of plastic tubing in
Just wondering if this is a big job to replace and what I'd be looking at cost wise for the part and labour?
See photos. Thanks
Parts likely not a vast amount, labour will depend on how much ultimately needs replacing, and thus the time involved, and your local labour rates.
Yeah, the Indy I've spoke to said the whole lot ( 2units) need replacing at the same time from the fuel tank, just doesn't know if the subframe needs to come down to access. Said around £350.00 but as you said could be less if labour is less
I highly doubt the subframe needs dropping, but there may be a multitude of plastic panels to remove.
That doesnt look like original fuel hose.
