Hi All,
Just purchased a T6.1, there's an old tracker fitted and camera in the cab, I'm not fussed about that.
But there are two lights on the front grille, there appears to be no feed to them, there is a switch up on the high level interior light switch console, but that doesn't turn them on. There wiring seems to go back into the cab behind the dash. Any ideas on how to remove?
Also next to the battery there was a black ground/neutral cable loose, it has an eye crimp on. I've got no idea what it is, I attached it to the battery to see if it had anything to do with the front grille lights and it doesn't seem to. All help greatly received.
