Front Fog Lights
Hello gang.....anyone have any idea what fog lights I can get to fit in front bumper lower spoiler....was also going to get DRl leds for the front bumper just above the fogs.... would be great if anyone can pass on where's best to get them and any similar front bumper pics.....thanks in advance!!
I have foglights kits if you are interested, can do them with generic wiring (work manually off switch) or factory wiring so you have auto cornering function (requires coding)
Hi Pauly....excellent can you qoute me a set for off the switch....whats the setup, plug into headlight switch or a new foglight toggle switch.....
2 x foglights and fog trims
1 x replacement light switch inc fog position (aftermarket chrome switch)
1 x wiring loom
The wiring loom has a red and black that needs 12v applied (red has inline fuse) then there’s a trigger wire that plugs in to the existing connector on back of light switch then a couple wires that connect onto the foglights
I have the foglights and trims in stock but will need to see what switches/wiring I have, if your interested send me a PM and we can discuss, your looking around £250 + postage
Hello Pauly, is there a different wiring loom for the fog lights to have the cornering function? I fitted the standard kit from Vanstyle with an auto switch and tried coding it on Carista last night, but it didn't work and a dash warning light came on that wasn't there before. Thanks.
