Front Assist
VanDamMan
Team Anssems GTB1500 2025
T6 Legend
Hi ...Has anyone had a front assist moment....Brake’s lock on and scares the S**t out ur..
had the dampers changed but still used the original 30mm springs the Dealer fitted ( this was done months ok ....so ride hight should not have really changed and assume it’s not effect Active cruise control as that’s been working ok)
t32 204 ( day vehicle only so no real load)
any thoughts ( or could be a VW gremlin )
Mines activated loads of times, but only when it should of done.
The only time it scared the crap out of me was when a Sprinter van turned in a dedicated right hand turn and his back end slightly came into my lane.. I didn't see it as an issue, but my sensor apparently did.
Still think that feature is brilliant though.
Yes agree great feature...had a thought my other half did hear a warning bleep prior but I’m a mutton Geoff
so is there a way of making the warning tone louder....
Mate, you must be hard of hearing :eek: the warning bleeps make you jump as much as the brakes being jammed on.
No idea if they can be set louder though.
