Fridge under passenger seat
denz1968
Hi all
As per the title - has anyone put a fridge under the passenger seat - i have a single captains style.
Any advice appreciated
There is the drawer one that's designed to go under a fixed bench seat arrangement, but it's capacity is quite low for the cost and in confined spaces it relies on you finding space for the compressor unit nearby.
I think that would be too long under a front seat and you'd have difficulty mounting the compressor remotely, wires can tuck under the floor but the copper pipes are much more delicate.
I'm looking at a van that has an Alpicool draw fridge under a RIB rear seat/bed. Looks very neat. Anyone got or done similar ?
Looks quite neat from the pictures on Jacksons Leisure here:
Only thought would be you'll need good ventilation of the compressor pack on the rear for efficiency.
Also from the look of the seals the drawer is removable from the fridge and seals all around the "drawer front". That's really neat for loading and cleaning but does mean a good seal (and therefore efficiency) is reliant on the drawer front aligning very well with the body.
I've got a Dometic CD30 on the underside of my Variotech 3000 - I swapped the frontage from the stock injecton molded Black Plastic to the flush Stainless Steel (aftermarket purchase)
Absolutely love it.
As my bed is on rails it was a bit of an engineering uncertainty how to power it as the whole seat can move up and down the length of the van. In the end I opted for a Anderson Cable loom.
