Hi
Just after some advice before i start to do the flooring in the rear of the van.
Do i need to remove the floor mounted brackets for the existing rear bench seat or can they stay in place when installing a ply floor to then be covered over. If removal is needed does that leave big holes that require covering, welding or similar. Not sure what to expect so trying to plan it out before i start
I was going to glue down ply packers between the ribs and sound / insulate then cover in ply sheet to put some sort of covering over that
thanks
thanks
