Coly
Intermittent Fault Codes caused by mice.
Where is the most likely place to find mice damage to the can bus wiring?
Eighteen months ago we had at least 4 mice setting up home in our converted T6 LWB camper. The main area they used was behind the passenger sliding door to rear corner.
Obviously they could have been anywhere but this area is where the kitchen unit is situated so ideal for them.
The fault codes have become more frequent as time passes so i suspect moisture ingress to the damaged area.
I can clear the faults and the fault may not come back for a hundred or a thousand miles.
Obviously intermittent faults are the worst but with the added complication of campervan conversion makes it a bit of a nightware.
Please, any help would be welcome.
