Fault code - B10A915 - Activation A/C Compressor, Open / Short Circuit to Positive
Stevio
Hi Guys,
Currently having issues with my Air Conditioning.
AC looks to be running as it should but no cold air coming from blowers.
Checked with diagnostics tool and that was the code I got.
Dropped the under tray to reveal the compressor, checked over the connectors but all looks normal.
Measured the solenoid and got 11.3 Ohms on the regulator valve attached to compressor.
Also tried to short out the connector going to the solenoid but code still comes up.
Any help please would be great!
Checked fuses in the cab, next to the battery and also fuses under the battery.
Stevie
Hi Stevie
Did you manage to find the problem, I have the exact same problem with mine and just found your question on the forum.
Hi Stevie
Hello mate, sorry for late reply. It went into VW Hawco in Inverness and they actually found a broken wire somewhere. This was then repaired by them. It was a while back now
