Factory coding settings
This all depends on vehicle spec and lights fitted.
I can revert it back to factory using ODIS.
I take it you haven't got a previous VCDS scan?
Reactions: mmi
Factory lights. No cc’d readings. I have access to vids for long coding. I need to check that my coding matches. Does this make sense? Cheers
There are 3 different types of 'factory' lights. H4, H7 and LED. Which do you have.
When you say 'playing up' what exactly do you mean.
Do you have high beam assist?
Have you checked the operation of the switch and High beam using VCDS? Does HB stay on if you turn it on from VCDS?
Can you post a full autoscan.
Van is at work at the moment. If I had an idea of the coding settings I could check and alter any that are not correct tonight. Cheers
