Exhaust Gas Temp Sensor Bank 1 Sensor 2 Issue
Lewisfordham
Hi guys, can see a few threads on here regarding the sensor at fault. I’ve had three fault codes pop up after a turbo replacement, P2031, P2032, P2458 (last of which I’m not worried about as should jump into regen when sorted). I’ve replacement the egt sensor with an NGK one and am still getting the same issue.
I’m not 100% sure where to go from here, have I made a mistake in not buying an OEM part and should I try that before doing anything else?
Also, if anyone know, should that egt sensor give some sort of a resistance reading when using a multimeter on it?
Thanks in advance for any help!
I had the duration code on one of our crafters 2019 , after a nox fault , luckily had 3 spares kicking about but only 1 worked ( after market) it took me several attempts to force regen but got it to kick in ran for 22 minutes then all codes cleared and no more limp mode.
I do believe it won't force regen if there are any further codes stored , I'll do some digging on tests for them temp sensor.
