Just wondering if anyone has managed to get a work around for fitting Vanshades with an Evo motion Design set of furniture?
Evo Motion say they wont fit there splashbacks.
Thanks, thats really helpful.In a similar predicament. Have Evo side unit. Van Furniture full length splashback/side panel (I think is designed for vanshades to fit), which replaced the Evo splash back. Want to replace my curtains. My observations:
The evo splashback has a much bigger window aperture, so suspect the Vanshade will not sit inside that. I did actually make a copy template and here is a pic of the plywood copy template and Evo silver splash back superimposed
The van furniture full length panel is the mdf one with black stripes. Its about 10mm thick. I have to have my Evo side unit tight to the side to fit my 115-8(?)cm Cali bench on rails. This means there isnt a lot of space behind the panel for the shade to go in. This might not be an issue for you.
I made a template of the panel to get the mounting holes in the right place and because I might want to replace it with something thinner in the future - the Evo splash panel is a better scribe and also includes the cut out for the C-Piller, which I added to the van furniture panel. I think the van furniture panel is designed to take a vanshade and sit much further out into the van (on batons) to allow space for the vanshade behind and probably sit above the side unit, not overlapped behind. It overlaps on mine possibly because of the raised floor for the cali rails. I could cut it to sit above the side unit but then it might foul the door of my top loading fridge. All doable, I just need to put a bit more thought into it.
Also will be looking for a cheaper option than Vanshades![]()
If you don't have a splashback where would you mount all the switches/sockets/12V outles and all the other gubbins?I don't have a splashback but will be looking to add vanshades with evomotion furniture.
I just need to sell a kidney first.
I'm having a pop-up power outlet in the worktop for 240v stuff plus USB ports.If you don't have a splashback where would you mount all the switches/sockets/12V outles and all the other gubbins?
Similar. On mine.I'm having a pop-up power outlet in the worktop for 240v stuff plus USB ports.
Then I have a USB outlet in the C-Pillar.
Will be adding further USB outlets from the LB once I know where I want them.
The lights are controlled from a switch in the B-Pillar.
Thanks, that looks good. Im shocked at that as all Cali beds are supposed to be the same, to fit the Cali furniture. /puzzled.View attachment 303382
This is my set up. T5.1, first installed during 2017.
My Cali bed is 115cm wide (just checked). I discussed this combo with evo when I bought the Evo5 front section and they said it would work if pulled against the wall and it did.
They now adjust and cut units for the 27mm floor so even betterThe extra Height of the Cali floor hasn't made much of a difference. Their fitting instructions do say to trim the bottom of the full height rear sections if fitting to a raised floor but this didnt apply to me as was fitting the front section only.
I fitted the home made rear low cupboard (with water jug), front gas locker, Van Furniture side panel and top cupboard this year when I replaced the electrics. The other thing that irks me about the Van Furniture rear panel is it is scribed so the stripes are parallel to the top (which slopes slightly on a transporter) not base unit work tops, so you can see them at an angle in the picture with the bottom black stripe disappearing behind the rear unit. I would much prefer them parallel to the work top and the angle being behind the over head lockers when its not so noticeable. If they were local and I had more time I think I would have returned it and made my own. As it was I was in a rush, had driven down to "MTB Van" (who are excellent btw) in Macclesfield from Dumfries to collect it, and distracted by a family crisis so pressed on.
Evo design component quality and customer service has been outstanding, lots of little details have made me very pleased. My experience of van furniture is too limited to say.
You can get Evo side units with a slim depth front opening fridge which will allow the sliding bed to come all the way forward.
On the Van shades dilemma. I think I just need to put some more thought into it. I need more space behind the wall panel, so maybe it has to go above the worktop but then there is the fridge door thing. I might make a new wall panel out of Aluminium composite panel (ACP), which is what the evo one is. Possibly get a print overlaid on it. I have two unused Evo splashbacks (even loooonger story) so may use them
I find Vanshades very expensive for what they are and the website unhelpful (the title bar takes up 40% of my laptop screen so difficult to see the product). I would need to visit to be happy with what I am getting. I would like to research other alternatives eg The ikea hack, all the ones on ebay, the other company that make them.
(I am also contemplating removing the gas altogther or even just buying a Crafter)
It looks like what we are trying to achieve is similar
Evo say their furniture wont work with Vanshades, have you found a solution?I don't have a splashback but will be looking to add vanshades with evomotion furniture.
It looks to me that it will work but not tried yet.Evo say their furniture wont work with Vanshades, have you found a solution?
I agree about Vanshades, but haven't found a better product but as I already have 2 fitted I'm hoping to go with them for the third window (behind the units).
Not being able to fit the Vanshades to the Evo furniture is therefor a deal breaker. I guess the solution would be to fit the vanshades pod and forget a splashback. Then Im struggling to fit the switches etc.
Yes, I think we are trying to find the same solutions.
BTW any rattles from the tambour doors?
Do you have the furniture already? Any pics so far?It looks to me that it will work but not tried yet.
Evo said their furniture wouldn't work with my Stide seat, but it's in there now haha.
I might be going to see a converter later this week not too far from Vanshades, I could maybe call in and speak to them?If Vanshades were anywhere near me I would go over and talk to them. I am not sure they are incompatible with the Units, just the splashback with the bigger size aperture and maybe the splashback/wall panel/whatever used, needs to sit forward of the back of the evo units and over the worktop to get sufficient depth. Whats the depth they require and how does the sliding window handles affect this?
Is your rear section full height?
I would have thought switch location is the least of your worries. Loads of places to fit.
(My Cali bed is probably from a 2013-2016 T5.1. That might be why different width. If yours is 112cm then have an extra 3cm to play with. Thats loads!!)
No rattles from front tambour in 8 years. Didnt use one at the rear as they take up too much storage space when open & rolled up IMO
Interesting. If I did without a splashback it would fit. I wonder if you fitted the Vanshades splashback after, so that it sits on top of the worktop rather than dropping behind then it could work.Does anyone have a vanshade fitted to the window behind the driver (sliding window) along with furniture from evomotion ?
Vanshades website say it might not fit depending on furniture as it protrudes by 20mm due to the sliding window.
At least you can have a set out for the fridge. Having the Cali bed or rails makes that another headache as well lol.I've had many headaches thinking about all of this haha
