You are a star! All working now! Went for a drive then run carista to clear logged faults. I was convinced I had dislodged something whist completing the install.Take it for a drive - the systems will self-calibrate themselves
Help T6.1 start/stop and assist unavailable
Hiya. I've had my passenger seats out today and part of the dash to run a cable in for a leisure battery. I also removed the starter battery to get to the cable grommet behind it. I was careful not to turn the ignition on until everything was back together but i’m now getting the following...www.t6forum.com
1) Could you by any chance share Carista "Detailed ECU info" (under Service menu)?carista
My van has the indirect TPMS system.Excellent!
2) Does your van have TPMS (tyre pressure monitoring system)?
I'm trying to decipher how the TPMS is coded in T6.1. For that codings from differently configured vans are needed (with/without TPMS, manual/DSG, etc.) - to nail down the common denominator.
DETAILED ECU INFO
ECU info obtained with Carista 610099 for iOS:
VIN: DELETED
CAN network gateway
Part #: 3Q0907530AG
Component: GW MQB High
Software version: 5423
ASAM/ODX identifier: EV_GatewNF
Coding: 030100044F05730001100058100F00010001070000000000000000000000 (hex)
[No fault codes]
Central electronics
Part #: 2Q0937090C
Component: BCM A0 Std+
Software version: 0943
ASAM/ODX identifier: EV_BCMA0
Coding: [none]
[No fault codes]
Parking/steering assist
Part #: 5QA919294J
Component: PDC 8 Kanal
Software version: 0073
ASAM/ODX identifier: EV_EPHVA18AU3700000
Coding: 8471151811 (hex)
[No fault codes]
Airbags
Part #: 2Q0959655AD
Component: VW22Airbag
Software version: 0506
ASAM/ODX identifier: EV_AirbaVW22BPAVW27X
Coding: 8800C00000000000800000CF008C40000065 (hex)
[No fault codes]
Instrument cluster
Part #: 7LA920941A
Component: KOMBI
Software version: 8500
ASAM/ODX identifier: EV_DashBoardVDDMQBAB
Coding: 23A5090A25842E00018E6A011401000080600000 (hex)
[No fault codes]
ABS
Part #: 7LA614517B
Component: ESC_high
Software version: 0800
ASAM/ODX identifier: EV_Brake1ESP90iBOSCHVN46X
Coding: 10552752C850E6850858E4A813696726393724B8 (hex)
[No fault codes]
Power steering
Part #: 7LA909144G
Component: EPS_MQB_ZFLS
Software version: 7160
ASAM/ODX identifier: EV_SteerAssisMNB
Coding: 0106 (hex)
[No fault codes]
Sliding door (rear, right)
Part #: 7LA959244D
Component: Slidingdoor_p
Software version: 0037
ASAM/ODX identifier: EV_SlideDoorPasseHufT6PA
Coding: 12 (hex)
[No fault codes]
Sliding door (rear, left)
Part #: 7LA959244D
Component: Slidingdoor_d
ASAM/ODX identifier: EV_SlideDoorDriveHufT6PA
Coding: 12 (hex)
[No fault codes]
Rear passenger's door
Part #: 7LA035593A
Component: SLD_Rx-Unit_p
Software version: 0031
ASAM/ODX identifier: EV_ReceiRearPasseSideHuf
Coding: 00 (hex)
[No fault codes]
Rear driver's door
Part #: 7LA035593A
Component: SLD_Rx-Unit_d
ASAM/ODX identifier: EV_ReceiRearDriveSideHuf
Coding: 00 (hex)
[No fault codes]
Heater & air conditioning
Part #: 7LA907426E
Component: AC Manuell
Software version: 0602
ASAM/ODX identifier: EV_AirCondiBHTCVN54XT6PA
Coding: B03110000810230001000800504001050000000000031100A00000000000 (hex)
[No fault codes]
Driver assist front sensor
Part #: 2Q0980653B
Component: MQB MFK 3.0
Software version: 1202
ASAM/ODX identifier: EV_MFK3ValeoMQB
Coding: 00010908114A4020501F00001030000006008000000000000000000000000000 (hex)
[No fault codes]
Adaptive cruise control
Part #: 2Q0907572R
Component: ACCCONTIMQB
Software version: 0372
ASAM/ODX identifier: EV_ACCMRRCONTIVW376
Coding: 3200470241FF8748949C815580508700000000000000000004 (hex)
[No fault codes]
Headlight aiming
Part #: 7P6907357E
Component: AFS-ECU
Software version: 0080
ASAM/ODX identifier: EV_HeadlRegulAFSMQBMAX
Coding: 0C8E020009200003 (hex)
[No fault codes]
Telematics
Part #: 5WA035284B
Component: OCUGen3High
Software version: 0035
ASAM/ODX identifier: EV_OCUGen3High
Coding: 06462000196898209005460160002607 (hex)
[No fault codes]
Auxiliary heater
Part #: 5WA963271C
Component: STH-VW37x
Software version: 0012
ASAM/ODX identifier: EV_AuxilHeateWOSVW38X
Coding: 3143221854121512DCE519 (hex)
[No fault codes]
Transmission
Part #: 0DV300046B
Component: GSG DQ500
Software version: 3702
ASAM/ODX identifier: EV_TCMDQ500021
Coding: 0014 (hex)
[No fault codes]
Engine
Part #: 05L906023
Component: R4 2.0l BTD
Software version: 1160
ASAM/ODX identifier: EV_ECM20BTD01105L906023
Coding: 0025003C0364050800000000000000000000000000000000 (hex)
[No fault codes]
Infotainment system
Part #: 3G5035820D
Component: MU-O-ND-EU
Software version: 0782
ASAM/ODX identifier: EV_MUOIMQB
Coding: 6460000800002000000000000000000000000A000000000000 (hex)
[No fault codes]
Obtained with Carista 610099 for iOS.
Download app: Carista OBD2
Facebook: Log in to Facebook
Thank you very much - just the last question - does the VIN start with WV1ZZZ... or WV2.ZZZ.... as this digit determines vehicle class (N1 or M1)? Thanks.My van has the indirect TPMS system.
Watching and hoping you can work this outExcellent!
Well, have to apologise for yet another question -
What are your engine and transmission codes - they can be found on configuration label below dash by steering column? Four-letter and three-letter codes.
The reason for the question is that your engine software identifier is something I haven't seen before so started to wonder if yours has one of these:
Innovative twin dosing reduces NOx emissions by approx. 80 percent
Since 2018, only SCR exhaust gas treatment systems have been used in Volkswagen models with diesel engines. SCR (selective catalytic reduction) technology significantly reduces nitrogen oxides in the exhaust gas. Volkswagen has now developed the next evolutionary stage of the SCR system –...www.volkswagen-newsroom.com
Adaptive, thought this was standard on t6.1@Spottyfrog just noted the Front Assist in the original post... however, a question remains:
Do you have starndard Cruise Control or Adaptive Cruise Control?
Thank you very much for the confirmation. I'm trying to create a configuration vs. coding relationship table for retrofitting "missing" components - was fairly simple on T6 but T6.1 is a different case.Adaptive, thought this was standard on t6.1
