Hi all.
The nightmare it’s back
Last year when I was in Europe it 1st time come out was a bit of panic as was driving quiet a lot and forgot laptop….but you guys helped a lot and get it sorted.
Turn out it was driving same speed for long time and after resetting all was ok till last month when pop up again I was driving a bit as well and was sure it will be same as 1st one…(was done by garage in poland and dint have copy of errors) saved then cleared codes and was sure that’s all but it’s back …. This time I was joining main road and pressed pedal a bit more and light pop up…
Copy codes and reset and back again today... tomorrow will check codes clear and do some measurements of engine block to see what it’s happening.
here both last errors logs
some errors are same oh and I did top up adblue month ego or so might buy and add addictive tomorrow just in case.
Any help appreciate! next month MOT and cant go with yellow light of dead t6
Address 01: Engine (2D2D2-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KG HW: 04L 907 445
Component: R4 2.0l TDI H02 3771
Revision: 23002001
Coding: 0025401443
P204F 00 [01100000] - Malfunction
Intermittent - Not Confirmed4 Faults Found:
31391 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0105 00 [00100000] - Malfunction
33262 - Reductant System Performanc1401090000
Shop #: WSC 10409 003 1048576
ASAM Dataset: EV_ECM20TDI03004L906056KG 004004
ROD: EV_ECM20TDI03004L906056KE_004.rod
VCID: 7CAA87B5A666074AD2B-8028
VINID: 9E606AAAA1D8A9A6011842410498D008B7
e Bank 1
31103 - SCR NOx Catalyst Bank 1
P20EE 00 [01100000] - Efficiency too Low
30540 - Throttle Position Sensor (G69)
P0121 00 [00100000] - Implausible Signal
Readiness: N/A
Revision: 23002001
Coding: 00254014431401090000
5 Faults Found:
24936 - Cylinder 3 Internal Pressure Sensor
P13D6 00 [11101100] - Implausible Signal
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Mileage: 225559 km
Date: 2093.01.07
Time: 12:31:35
Engine speed: 1934.50 /min
Normed load value: 0.0 %
Vehicle speed: 39 km/h
Coolant temperature: 90 C
Intake air temperature: 40 C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.304 V
Cylinder head: pressure sensor 3 bank 1: raw value: 41.6 bar
33262 - Reductant System Performance Bank 1
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 0 km
Date: 2093.01.07
Time: 21:12:30
Engine speed: 0.00 /min
Vehicle speed: 0 km/h
Coolant temperature: 80 C
Intake air temperature: 33 C
Voltage terminal 30: 12.234 V
Unlearning counter according OBD: 33
Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
Throttl.valve adapt. 1 bank 1: posit feedback - Specified value: -0.01 %
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 100.00 %
Throttl.valve adapt. 1 bank 1: posit feedback - Offset closed: 0.41 %
Throttl.valve adapt. 1 bank 1: posit feedback - Raw voltage: 4.740 V
16230 - Control Module for Instrument Cluster
U1019 00 [00100000] - Missing Signal for Oil Level/Temperature
[Instrument cluster control moduleMissing signal oil level/temperature]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 225199 km
Date: 2092.01.26
Time: 19:53:21
Intake air temperature: 18 C
Voltage terminal 30: 12.359 V
Unlearning counter according OBD: 2
Air mass at air mass meter 1: 0.0 kg/h
Standardized air flow ratio: 1.000 counts
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 111.17 %
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
Charge air pressure: specified value: 0.000 bar
Absolute intake pressure: 101 kPa abs
Mean injection quantity: 0 mg/stroke
Index of current engine mode: 4
Index of next requested engine mode: 4
Index of engine target mode: 4
