EMBED testing - seems to behave differently than used to do
mmi
Senior Expert
VCDS User
Moderator
T6 Master
Hmmm.... in my real post didn't work as expected - should have taken to the actual header - instead took into the beginning of lengthy post.
Trying the same below:
EDIT: Indeed, doesn't take to the end of the post where the chapter "Heater unlocking" resides
Another
Even more weird as took into beginning of the thread - not into the chapter "The above zoomed in y axis" in post #3
An old one which still is ok in an earlier posting - post #3 in the thread. But let's see what happens now...
Possibly only new EMBEDs go wrong - the above should have been a link to "Test of wastegate actuator" in post #3 of the thread - instead goes to beginning of the thread.
See the old EMBED in post #126 in here - it's still seen as "Test of wastegate actuator" (at the bottom of the posting - the posting itself linked here seems to work - takes to beginning of the post)
Should get this kind of view... inside of post#2
Instead - jumps into beginning of the thread
However, using the EMBED link directly in a browser works correctly.
Hello from North Lincolnshire
Not the page title
