Power-latching would pull the tailgate the final few cm shut, so check if yours is now not closing fully. If it’s died in the closed position then it’ll be fine.Hi
When I used to slam my VW t6 rear door (it’s not barn doors but the other one I’m not sure of the name of) it used to make an electronic noise after it closed.
Now it doesn’t. How do I fix this? Could this mean someone has tampered with my door?
Thank you
Not sure about the air-con, but any specialist would likely be able to diagnose that.This sounds more like what it is. It seems to be locked - I can’t force it open anyway. I guess I need to take this to a dealer to repair?
I’m in Essex also. I bought it at VW Loughton a few years ago. I also need the air con sorted cos there’s sometimes a weird smell when I first start the engine
It still all works fine. I was just curious why it no longer makes the electric soundNot sure about the air-con, but any specialist would likely be able to diagnose that.
The soft-touch handle for the tailgate should still work - perhaps that’s the problem, which leads to the power-latching motor not turning (because it’s not receiving signal from a defective handle)? I’ve got PL myself but haven’t had a problem -
Others have, so have a read up and see.
One thing it could be is this:
Power-latching Woes
To get the tailgate open when power isn’t being supplied to the handle or power-latching motor, you’ll need to pull on the rod itself to free off the latch.
How do I fix this?
Is it broken?It still all works fine.
Sorry rather than saying “fix” maybe I should have said “restore the previous behaviour”Is it broken?
Hah yeah I get you. I’m guessing the electric noise was power latching, so I’m now guessing it’s now not working.Sorry rather than saying “fix” maybe I should have said “restore the previous behaviour”
Can you try closing it gently to see if a motor pulls it closed the last few centimetres?The old behaviour was I would slam it and momentarily after an electric noise would pull it completely shut.
Now when I slam it there is no noise but it still stays closed/locked.
I can open/close the door without issue and it is locked when I lock the van.
Sorry I’m confusing
So I can hear the latch system when I open but when I gently close it doesn’t pull it shut. It definitely used to and that’s the behaviour I’m keen to restoreCan you try closing it gently to see if a motor pulls it closed the last few centimetres?
3 minutes in is an example.
If I close mine ultra softly, I can defeat the power-latch and it’ll stay ajar.It’s continuing to work with the engine off now. Not sure why it ever stopped?
