Tried to send this directly to Dellmassive but apparently I'm only allowed 420 characters. This is what it's all about....
I’ve started to clear this area in the van ready to sort the wiring for the new Renogy charger/controller but I’m not sure of the EHU system. I’m a bit nervous about the mains voltage wiring and still haven’t got my head around the test unit. The feed comes straight from the input on the side of the van to a 13amp socket inside then, apparently, via this testing socket (which I had to smash to get out) down to a standard 12v charger. Is it ok to keep this charger in the system. I’m not quite sure what is being tested with these buttons. Should I replace the smashed unit with a similar one or can I replace it with a plug in RCD tester to give me some extra wall space and do I need to include a trip switch consumer unit somewhere in the mains circuit?
