Drivers side rear underside grommet
  • Thread starter Thread starter EAN
  • Start date Start date
EAN
I’ve searched and read mention of a cable route in through from the rear behind the bumper using an existing grommet.
Does anyone know if the grommet circled in the pic (not my van, just a convenient pic taken from the Forum) provides a cable route through and into the offside rear quarter, or, if it doesn’t, where the right grommet is located?
@JumpShip Which one did you use?
I knew you were gonna ask ....
Well i was pretty sure it wasnt that bung but having now crawled underneath to look it appears i may have been wrong 😳 it could well have been that one 😁
Its actually hidden up under the exhaust heat shield so not very easy to see .
Reactions: EAN
Thanks for taking a look.
So, for completeness, and to help others, the large grommet circled in the first post doesn’t provide a cable route through into the offside rear quarter.
The grommet just behind the rear wheel is the one to use.
I’ve run a cable through from inside the rear quarter and out to the tow bar.
Pictures attached in case anyone else finds it useful.
