Door Locking Help !!
Silverfox
Suddenly today for no reason,when I press the keyfob to open van,it's only opening the front doors and slider,but not the barn doors.
If I press it a second time,then it opens the barn doors.
Could I have caused this by sitting on the fob by accident,as I haven't messed with anything on the van.
I haven't got vcds or carista to check for any fault codes,so wondered if I could do anything on the fob to
revert it back to how it was.
Any help appreciated.
I think ours has always worked this way - will check tomorrow.
Pete
Including or excluding the back door from the central locking is definitely an option in VCCDS, but I don't know how it could be changed via the key.
Ours opens all doors on first click...try a BCM reset....?
Possible sticky lock actuator....?
Possible wire issue in door loop....?
Thanks @Dellmassive,vans still under warranty,so before I start messing I'll give the dealers a shout
tomorrow first.
