Standard OEM WEBASTO AUX./STATIONARY diesel heater on T6 is rated @ 5kW.
Would the mounting bracket supplied with this kit be ok?I certainly would not mount a 5Kw on one of those - they flex too much and will work harden and fracture. I would not recommend them for a 2Kw either.
The oem offering is rubber mounted and is very substantial.
The 6 hole version is 3mm steel and the 2 hole 2.75mm. The 2 hole version has a built-in failure point where the metal fatigue develops.
So you wouldn’t use that then?That's the flimsy one the same as the one bottom left in my pic above - you can see the difference between them!
